Power Saving Watchapp
etromora
This watchapp is designed to use as little power as possible overnight. It achieves this by not doing anything until you press the Select button which lets the processor stay in a low power mode.
It also features a daymode if you happen to run low on battery during the day. You can enable this mode by holding Select for about 5 seconds.
Power saving tips: https://www.notehub.org/08ooy
  • Developeretromora
  • Updated2014-11-09
