Contopus Phone Connection Monitor
Chatopus
Contopus monitors your phone connection with your Pebble in the background.
When your phone goes out of range, you will get a vibration alert. You can then snooze or dismiss your alarm.
It works with all watchfaces and regardless of any screen you are in your Pebble.
You will never forget to bring your phone or miss any notification due to a bluetooth disconnection.
Configurable to disable vibration during Quiet Time or when you are sleeping. Hence, permission for Pebble Health is required.
  • DeveloperChatopus
  • Updated2016-11-25
  • Version1.6
